Discuss Fuses and tails. in the UK Electrical Forum area at ElectriciansForums.net
hi there doing some work with my gaffer just for my own mind a 60 amp fuse at the main cut out with 16mm2 tails well i assume they will be what size of main switch for the consumer unit ? could 100A main switch be put on that ?
yeah thanks guys my boss said no isolator what fuse will he pull will he pull both? he’s a bit crabbit when i ask things
Forgot to finish my last post. I intended to also ask what the job was that was to be carried out?
you but could 100 amp main switch be used ?
[automerge]1574191332[/automerge]
just for my own mind it the pictures previous what fuse will he pull will he pull both or just one?
[automerge]1574191354[/automerge]
new main board what fuse will he pull tho
I assume the job is to replace that consumer unit, because as it stands, it’s rough.
If you’re upgrading the tails, then the neutral will have to be disconnected. Otherwise, no... pulling the fuse will sufficiently isolate.
Just pull the fuse that’s going through the meter.
The other fuse does appear to supply a cable that goes straight up- possibly to an upstairs flat (?).
What brand board are you putting in out of interest? And are you using RCBOs?
no upstairs might be next door tho and so he won’t need to disconnect the neutral it’s safe him just pulling the live fuse
You are worrying too much. He is the guy who is on site and can see everything. Watch what he does, and ask questions. If he doesn't want to reply then go elsewhere for your training.
Just one other question - is it actually you doing the job? No offence intended, but your questions come across a bit odd in their manner.
Reply to Fuses and tails. in the UK Electrical Forum area at ElectriciansForums.net
  • Locked
My house was built in the 1930s, The fuse in my service cut out is 60Amp and the wire coming from the street has a 16mm2 copper core(easy to see...
Hello Shop with a 100A main fuse LED lights few amps max, cash tills, cash machine, roller shutter, auto door, nothing pulling much power but...
Hi I have a domestic installation to rewire and the main incoming fuse is 80 amp so i am using 16mm double insulated tails, is the main earth size...
Hi lads 5 year safety inspection the spark put the tails back and later line 2 of the 3 phase blew blowing the box off the wall and taking out the...
5K
