How much difference would using paralleled scaffold tube (galvanised steel) earth rods instead of paralleled copper plated steel earth rods? I suspect scaffold tube rods would be more durable, long term, having looked at many old copper plated ones... .The rods are to ground a 22kW single phase generator.
Depending on where you are yes you can use galvanized pipe. You are required to install them a minimum of 6feet
Getting the right metal is important with canal boats and the like, but in most cases it does not matter. It is where the metal is on the voltage scale, wrong combination, and it can be eaten away.
I stick with proper copper bonded rods. Scaffold tube might survive physically but grounding performance and long term connections are bigger issue.
Any parallel rods have to be placed outside the zone of influence from each other, I have only ever used the correct copper rods, why would you use anything else?
Aluminium shouldn't be used for an earth rod.
