C
craftydayv
i'm am looking to instal an electrical supply to my garage using the existing consumer unit that supplys the house with electric. i have checked, and the house consumer unit has a spur for a breaker to be fitted (MEM AD10 HED CONSUMER UNIT). so far i have a 10mm swa that runs from the garage and into the house.(the swa is aprox 25m long).
the consumer unit will run an outside pond pump (16amp RCBO)
" " pond heater (16amp RCBO)
" " lighting (6amp RCBO)
indoor lighting (RCBO)
" " socket ring main (32amp RCBO)
i was told that a six way garage consumer unit with 80amp isolator switch and RCBO rated as above would be ok
along with a 50 amp MCB for consumer unit in the house.
just need to know if this info is ok before i purchase any of these items.
Thanks Dave
Thanks Dave
