R
ryanwoodward
Hi All,
I'm new to the forum and wanted to ask some advice on a job that is causing me a right headache. In short I have a detached garage which used to have an outbuilding attached to it. The outbuilding was demolished a while ago and before doing do so I disconnected a rats nest of a junction box to isolate it before knocking it down. When it came to reconnecting the garage I blew a fuse in the main fuse box and decided to leave it all disconnected so no power to the garage. I've made do with running a cable reel into the garage whenever I've needed power in there .
So it's been my nemesis for a while and want to sort it out. I traced all the wiring and thought I was good to go but I've hit a snag and wondered if you could give me some advice?
I have two feeds from the house going into the garage using pyro cabling. One of the feeds comes from the main fuse board externally running to a bulk head light above my front door. It looks like it has a junction box next to the light which then runs off to the garage. This is on a 15 amp fuse on the board.
I then have another fused spur by my cooker switch in the kitchen then running out to the garage again using pyro cable.
So I thought the cable from the main board is the lighting and the cable from the cooker switch is the sockets. (With having two feeds). I have hooked up the fuse from the main fuse board and I now have a live feed powering the bulkhead light I mentioned and have tested this in the garage and its live there too. 1 down 1 to go I thought. I then tried the same from the fused spur in the kitchen but was getting no power in the garage. The fuse is good in the spur. So I had a look in the spur and there doesn't seem to be a supply to it?!? It's connected to one end of the pyro and runs to the garage and then the other end of the pyro is disconnected. And this is what's confused me as I thought I'd nailed it in that I had two feeds for lighting and sockets.
Any advice you could give me? My initial thought seems to be dead in the water so I'm now thinking that the fused spur by the cooker switch was probably used to switch on an old security light which has been long disconnected. And 15amps seems to be too high for the lighting....so do you think this 15amps feed is for both and just a single supply? If so I would probably want to fit a garage rcd consumer unit so that I have the lighting and sockets on separate circuits. If so is 15 amps enough?
Any advice would be welcome at this stage.
Many thanks
Many thanks
