Guest viewing is limited
hello,
I'm very new to this trade and do industrial installations. A friend employed an electrician to run a feed to a new consumer unit in his shed so I went to have a look at it out of curiosity to see the correct way it's done. I haven't done any domestic work yet but I don't think it's correct. Could you help please?
It is a PME system. He has taken a 2.5 t+e cable directly out of the 100amp isolator in the suppliers electrical box and run it 5meters in conduit and then under their decking for another 5 meters and the last meter is buried under some cement between patio slabs to supply the new fuse board. The fuse board is rcd protected and has 2 circuits. 1 is a 6amp for one light and the other is a 32 amp for 1 double socket on a radial, not a ring.
It doesn't seem correct to me from listening to more experienced men on site.
Thanks in advance for any help.
Quite possibly Des. When I was looking at it, it seemed more the sort of work a bad apprentice or mate would do.
If he thought he was going to get accolade or approval from us, afraid he was sadly mistaken.
I've got nothing against an apprentice doing a little side job like changing a light fitting or socket etc. But when you get to things like this, leave it to people who are capable.
What always makes me shake my head with Domestic electrics
I have no problem with anyone doing unpaid work in their own home so long as they research what it is they are supposed to do,then make a half decent attempt at getting it right
What does irritate is the clueless not knowing they are clueless
These are the dangerous Muppets,whether its an apprentice,fast tracked spark or the Diy ones who "can do electrics"
Yep I know what you mean, a friends husband is so clueless with electrics it's painful.
Sadly he thinks he's gods gift to the electrical trade. He's so bad that I've had to tell her, call someone else next time he screws up. I'm done with clearing up his mess.
In domestic it's called a Consumer unit or CU not a DB.
Have to disagree there - a consumer unit is a type-tested distribution board so DB is also correct. In fact the term DBO (Distribution Board for use by Ordinary Persons) is now used in harmonised documents. I never use the term CU.
Wales
Garage electrics help needed please
Jacko,
Pete999,
