H
Heligav
Hi guys I'm new on the forum, just had the garage wired up but the spark only connected 1 socket when he was supposed to do a couple, fed up of calling him and doesnt look like hes got any intention of coming back!
Hoping i could put in 5 sockets in total maybe, as you can see from the pics theres an mcb 16amp that runs into a junction box then to a double socket also the breaker in the main box in the house is a 16amp one aswell.
what would be the best way to do this, twin earth 2.5mm2 running spur off spur?
16amp in house main box---16amp mcb---junction box---x2---x2---x2---x2---x2
any help would be great guys, thanks
Is there an rcd protecting that garage db at house end? Why did he use a junction box and not just run a new length of cable to the socket? Is your earthing and bonding up to date?
This is whats in the house, garage one is on the left. Cheers for the quick reply!
They ran a new length of cable from the house and put the box in the garage as therewas not one before and the electrics in the garage would not work
Was done 18 month ago there was already some cable when we moved in, but sockets didnt work.
Is this an ok way to wire in the sockets as described in my first post? Goin screwfix get the stuff tomorrow.
Why do you need 5 sockets? one of the domestic guys could help more but that might be a 32A for that and a ring circuit.
It's also illegal to do if you don't have papers, if it catches fire mate look at the other post in this thread. You would be in a world of crap.
Get the stuff and ask a sparky for a homer wont cost that much if you supply the materials.
Better safe than sorry must be plenty of dudes on here who could rattle it up with their eyes closed for ya.
If your going to do it anyway why ask on here if its ok? How will you test you work after? Do you know what results to look for? Is the earthing and bonding up to date? Does that rcd work within limits? What is the EFLI of the circuit?Lot of things to think about
How many double sockets would be safe, could get away with 3 in total. Would the original diagram be safe with 3/4 sockets? On 16amp mcb?
