Please come check out EFbot; Testing thread is here. Come see what it can do. . Tag it in any thread using @efbot you will need give it a few seconds and refresh a page for it to post a reply post.
Preferable to have a circuit breaker but BS3036 should be OK if calculations are correctly done.
If it is a TN earthing system then SWA does not need RCD protection as it has an earthed metallic sheath (so long as you earth the armour!)
