Discuss Garden lighting help in the Lighting Forum area at ElectriciansForums.net
Hi guys been a while,
I have a customer asking for quite a large outdoor lighting and power installation
It is going to have a kitchen area built which they want 3 x double sockets and 6 spotlights with a switch
the kitchen will also have a gas cooker
A shed with 2 double sockets and a pendant with a switch
around 20 lights around the full garden which are switched by separate switches half on one half on another
I suggested taking a 6mm swa from the mains inside the house to the shed putting a board in the shed and feeding everything in the garden from there
the customer didn’t seem to like this idea so was wondering if there was any other options to feed this
I doubt that the customer is in any way interested in where the garden lights are fed from, just where they are switched from.
What's the problem in feeding the lights from the house?
I was thinking of drilling through the back of a switch for the lights and back of a socket for the sockets but thought adding an addition 31 lights and 5 sockets may be abit excessive and better practise to put on there own circuit seeing as they are positioned outside not in the house
maybe I’m overthinking it
I'd stick with the SWA to the garage, direct from the consumer unit ,or preferably a separate switch/fuse adjacent to it for better discrimination. There should be no RCD protection at this end.
You don't say what type of garden lights they require, but with this quantity of lights, some thought needs to be given to the inrush current when they're switched on, to ensure that the switches are up to the job, and that the MCB doesn't flip out on the magnetic. It's possible you may have to go to a C curve MCB, which will affect the loop impedance for the light wiring, so this should also be taken into consideration
You agree coming from the mains to the shed would be better practise
They are led some are spot lights some are spike lights and some are up down lights
thank you for responses
I find it always helps getting a second opinion
My personal preference woukd be like you say a dedicated supply to the shed and install an rcbo board there to feed the various socket and light circuits.
you could run individual smaller armoured cables back to the house, but that’s a lot of faffing as they might require different routes back...
Does the OP know why the customer doesn't like the idea of a supply to the shed, with everything supplied from a small board there?
Some objection to the supply cable presence or installation?
Perception this would be unduly costly?
Some other reason?
Some other reason?
it would require digging up the front garden and path at side of the house which they didn’t really want to do plus it would be costly as the mains to the shed is over 50m
Reply to Garden lighting help in the Lighting Forum area at ElectriciansForums.net
I've had a search, and found an old thread from 2016... but was wondering about modern views on this situation. I've come into possession of...
Looking for some cabling advice for my garden project. I’ve put together this diagram below, which hopefully explains what I’m trying to achieve...
Hi all, Curious one and hopefully some one of you could give me some advice. A customer has had a steeltech shed installed at their premises. A...
Hello all, Looking for help here as I've come across a strange call-out today. Bare with me here: Got a call from a customer saying they had...
Hi guys, long time lurker first time poster. I have an SWA 3 core armoured cable buried that runs to my back garden. This originally serviced an...
