Discuss garge lighing in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
A
andyd55
Just a quick question to get some expert opinions, installing some lights in my garage, surface mounting cables in 20mm conduit, what cabling is best to run within the conduit, ie 1.5mm twin and earth or can I use individual 1.5mm brown/blue/earth conduit cabling or a mixture of both depending on what I need?
Single cores are better in conduit as they are easier to pull in and there is no issue with bending radius.. If you use twin and earth the bending radius at Boxes and Manufactured Bends is a bit tight if your using Inspection Elbows i thing it is to tight.
Reply to garge lighing in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all, First post here, hope I'm compliant with the rules! I did do a quick search before asking this, but I couldn't quite come up with the...
Hi all, I'm planning on adding some lighting to an old stone shed, there's currently a 2.5mm² SWA supply to the shed only supplying one IP rated...
Hey guys, looking for a bit of advise on the installation of an outside light. I plan on chasing out the plasterboard and running a cable from a...
Hi All. What is the best/preferred method when connecting 20mm conduit to a back box of a socket on an outside wall ? I am connecting a BG...
