Discuss gas earth bond in the UK Electrical Forum area at ElectriciansForums.net
The more I read of threads like this, the more and more convinced I am that it's not what you know, experience you have or how competent you may be, it's the ability to spout Bull at interviews!
edit: I'm referring to the EDF geezer!!!
So what has the EDF left you in writing or has his /her pen been replaced with a volt pen. Seriously I would like to know what they have said is the problem and I would like to think they have documented it!
Once again we are talking amongst ourselves and the OP has went quite
Just to add yet again it appears that someone wants an answer before they visit site it would have been better if the EDF stick came along with a and I did a Ze test and found.........
Reply to gas earth bond in the UK Electrical Forum area at ElectriciansForums.net
No waffling, going to get straight to the point. Main water on the exterior of the building in plastic. Changes to copper inside the building...
Iā€™m not working on thisā€¦ not yet anyway, but can someone tell me why thereā€™s a fuse or a link on the earth here? The green wire is bonded to...
Greetings, I am homeowner and looking to confirm if I will need earth boding to water pipes. There is already earth boding near Gas meter and the...
TNC-S main supply with 16mm swa supplying garage consumer unit from main consumer unit in house, then 4mm swa supplying pond equipment through...
Hi all, it's been a while since I've been on, apologies. I am debating whether I need to replace the bonding to the gas meter. The meter is...
