Discuss GE subpanel wiring issue in the DIY Electrical Advice area at ElectriciansForums.net
evanLo
I had someone wire up a subpanel for an electric clothes dryer and it wasn't working. Showing low voltage error code on the dryer. Long story short, after I checked everything else I figured out it was the box he put in.
But I'm wondering if I'm right as to why it didn't work? He said it was a 'bad box' but I sort of think it was wired incorrectly but I've never used\seen this type box.
I attached a couple pictures.
The dryer is the two 30 amp breakers (there was a piece of copper connecting the breaker throws). I would think that one breaker would have to be connected to one hot and the other to the other. But both breakers are coming off of the black wire terminal on the left.PXL_20230416_163852114.jpgPXL_20230417_154737231.jpg
Reply to GE subpanel wiring issue in the DIY Electrical Advice area at ElectriciansForums.net
I’m running wires to the basement for future basement finishing. I’d like to add two circuits of outlets (one on the finished side and one on the...
Hi everyone. The title should sound crazy enough, but it's what happening in my 72-years old home we've purchased 2 years ago. I found the crazy...
In July I moved into my new home with Schluter DITRA heated floors in the bathroom. The floor quit working in December, and my GC and a rep from...
Replaced our old 240v hot tub with a new one, which also uses 240v for motors, heater, etc, and 120v for low amp LEDs and touch screen control...
Hi everybody. We had a Texecom system installed 3 years ago. Earlier this year we had a battery problem and the installer came back and changed...
