P
Paul.M
Where do we draw the line? Who do or don't we help? What's your opinion on giving advise to DIYers therefore potentially taking jobs away from electricians?
It is within the forums best interest to give help and advise for those that seek it. With money being tight for most people they want to do it themselves, how do we approach it?
I've put this in the Arms for Arms members to discuss first, mods can place in the general forum after you lot have your say.
sometimes i think we get threads like, "how should this be done, as my electrician has run off", when in fact they want our advice ect. I think its a very fine line to tread, especially as the forum cant allow members to be turned away all the time.
i think that in most case's we tell op to get a spark in if needed, but also offer advice on changing socket fronts, switches ect.
i understand that to some blokes, this might be taking small jobs from them, but i beleive that if we didnt offer advice, they would have a go anyway, and then maybe hurt themselves, and nobody wants that.
Basically everything that john has said is 100% correct.
Anyone with basic DIY skills will have a go at most things including electrics and so i think i would rather give the basic advice or recommend calling in a competent person.
As said, they are going to have a go anyway, so the least we can do is make sure they understand what they are trying to do and hopefully saving themselves or someone else a nasty surprise.
This is an open forum. The general public can join in. Atleast a few of them are sensible enough to ask advice before blowing their side cutters into molten metal art work.
It seems to me that its very obvious (generally) if someone knows what they are doing or does not know what they are doing. I spose advice should be given out on that level of understanding.
Lets all be nice...
Terminology is the normal giveaway that prompts me to say 'please call a competent electrician'.
It's a waste of effort trying to limit advice now, a quick search across a few forums will probably turn up a number of answers of differing quality for the DIYer to make an uninformed choice!
I normally look at it this way;
does it need testing?
is it more than a minor works?
does it need notifying?
if the answer to the above is yes than i will advise accordingly. i would rather advise people looking for advice than have them just get on with it and do it not only wrong but injure themselves or others.
I don`t believe that by giving advice that it takes it away from the trade as most if they are going to do it will regardless of the advice they get but at least in some cases they very may well do it properly due to advice.
I don't have much money...but ive got some cable which my mate stole from his stores at work...
This cable is that 'skinny' type of cable...you know the sort, its red, yellow and blue.
Ive got meters and meters of 'skinny' red, yellow and blue cable. It was free!
We used to have a gas cooker, however, ive now got a new mate who works in a large warehouse. He told me he was doing a new range of cookers, they were of the 'cheap' range variety.
He asked me if I had an outlet to plug my new 'purchase' into. I replied that I had some 'skinny' red, yellow and blue. He said it would be fine.
The 'skinny cable' is 2.5 milliohms in thickness.
Is the above okay?
Im really looking forward to me first roast dinner.
Is the above okay?
Please call a competent electrician, 2.5 milliohms might not be thick enough and you might want a 40mm RCD too.
The below is from topquark:-
Preventing work by un(qualified/authorised) persons. Some half baked thoughts to provoke some discussion:
How about controlling the availability of parts? At the moment, joe public is allowed to do like/like replacement. For bulbs etc that's not too bad (but not ideal, mains/low voltage, electronic contolled for LEDs etc!). For replacing wiring accessories, that's problematic. By changing the wiring accessory you ARE changing the circuit (and, more importantly potentially introducing faults, Class I/II etc).
That leaves a problem. Requiring folk to todays fully qualified electrician for a "simply" accessory replacement would not work. i) most sparks wouldn't want to do such a trivial job (in isolation). ii) most people would balk at having to employ one to do that level of work.
So...
How about a number of different qualification "levels" based around proven competency. That could include a level needed to change existing accessories. You could also have other levels based around the type/nature of the work ie:
Anything involving new/replacement cabling etc (details would need to be thrashed out).
Then...
Anyone requiring a part had to have proof of that level of competence (whatever form that would take).
Once you had that in place you can then police who had access to what type of parts.
I'd be interested to hear views on whether that might help in cutting down on unauthorised work.
Some of the levels may need additional qualifications to prove competence ie 2382 for anything involving wiring new circuits etc. There may need to be additional qualifications/exams to cover this. I'm sure C&G would light up at the thought of joe public having to have a qualification for buying switches/sockets etc.
Cheers
Martin ...
Ah, this old favourite again.
Some good points here - I agree that a DIYer is going to have a go at piecing together whatever parts they've got anyway and we're not going to be able to stop them by telling them they need to pay an extra fee to the council or telling them their sheer and utter incompetence and stupidity will burn their house down with their family in it; that will just make us sound like nasty people.
At the same time I don't think restricting the sale of materials is a workable idea; as mentioned you would need to prove competence in some way which is always a contentious issue - is it right to stop a retired sparky from doing some DIY because he didn't update to 17th edition? Someone who hasn't done the 2330? And who polices it? Some central government body who will probably get everything wrong and mess it up, or a private organisation such as napit or elecsa who are only after your money so will pass everyone who pays the fee?
Even the 'competent persons' schemes' aren't working as they should - they seem to be saying that anyone who does a lot of work and is able to pay the annual fees must be competent; after all, the difference between a DIYer and a DIer is a fee, a simple test and a test meter.
The solution is definately some way of encouraging homeowners to get someone in rather than discouraging them from having a go themselves; insurance companies, advertising in sheds, publicity in the media, improving the image of the trade... Every little helps.
I absolutely agree with NovusSparkus and I made a point on a similar thread that if the government put 50% of the self assessment advertising budget into Part P awareness campaigns then we might start to see it working.
There's nothing like the prospect of a fine to help people to weigh up whether to DIY or get the professionals in.
The public are still clueless on Part P after all these years and in my book that's a complete fail!
Its simple really. You either choose to reply to a thread, or choose not to. If you do reply then we should always be civil. If you dont want to help DIY'ers or anyone else for that matter then just move on.
We must avoid this forum going the same way as some others that we are all familiar with.
Cheers.......Howard
