Discuss Google Nest Wiring (Combi Boiler UK) in the UK Electrical Forum area at ElectriciansForums.net
What boiler have you got fitted, most boilers have a permanent feed for pump over run after the heating is turned off to prevent heat build up in the boiler and also with a combi to run the hot water function
Boilers will usually have one or sometimes two terminals where the CH control is connected this can be either a switched live to a single terminal or a dry contact across two terminals
Hi, the circuit is pretty simple however shouldn't the boiler also have a permeant feed for the hot water as terminal 3 is the switch line for central heating?
That diagram is purely for the basic nest wiring and does not include the rest of the wiring required for the boiler.
So yes the boiler may require other wiring such as a permanent live, frost stat, condensate pump etc depending on the specific details of your installation.
Reply to Google Nest Wiring (Combi Boiler UK) in the UK Electrical Forum area at ElectriciansForums.net
Hi folks, I'd like to get my Nest thermostat up and running with the gas combi boiler (Worcester Greenstar HIghflow 440 Standalone). FYI - I...
I have not had to do the wiring for a wet underfloor heating system before. I think I started a thread fairly recently and had some very good...
Hello, I hope you are well, I have fitted a few Nests but only to Combi, S and Y plan systems just been looking a job where I’m doing the kitchen...
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
Hi all, taken on a new build project and they have quite a large property with three separate manifolds. I have wired before with one manifold but...
