Just to keep you all updated. Train4jobs have not responded to my last email which included the breakdown of my course for which I was given at the time I signed up. It clearly states im doing level 3.
I a contacted citizens advice and I have a meeting with them next Thursday
Hi
I understand your frustration but you will have to separate your dealings with train4jobs from the exam requirements to progress to be a competent electrician.
The bottom line is that completion of the 2365 Level 2 will not put you anywhere near being capable of progressing to and passing the AM2 or being able to complete the 2357 bridging unit (you will not have achieved the guided learning hours or have the necessary exam passes)
If you are not already in the industry or have a current background in electrical work you are probably on the correct course (notwithstanding the miss selling) , I already completed an electrical apprenticeship many moons ago and have had to go back to the beginning to take the level 2 again (I needed the refresher!)
It is all fairly academic whether you are on the Level 2 or Level 3 as there are units which are necessary and core to both courses which have to be completed. If you do not complete the relevant unit at level 2 you will simply have to complete it at Level 3. If you enrol on the 2357 you will simply complete the same academic learning. The units are are just different paths to achieving the same goal. L2 is an introduction for those with little or no experience, L3 is for improvers and 2357 for those working in the industry (Apprentices etc).
This is why there is a bridge from the 2365 series to the 2357 as many of the core units are the same.
As an example the following courses have cost me with a competitively price training company £5595 and are broken down as follows. This is the minimum path to being a full scope electrician (with a lot of on site experience added of course!)
L2 2365 £1600
L3 23657 £1800
2357 Conversion £1200
2382 (15) £400
AM2 £595
Have a look at the scheme booklets to understand where the crossovers are.
http://cdn.cityandguilds.com/Produc...02_L2_Diploma_Qualification_handbook_v1-5.pdf
http://cdn.cityandguilds.com/Produc...03_L3_Diploma_Qualification_handbook_v1-3.pdf
I hope I haven't been the merchant of doom and gloom, http://www.thompsontrainingltd.com/ who I have used are very good and their website has a good breakdown of relevant courses and pathways, perhaps give them a call if you would like some advice, distance learning and training days may suit your personal circumstances.
as far as I was aware I could finish this level 2 (2365) and the other few units on level 3, then do the bridging unit for 2357 which will convert 2365 into 2357. Then I can sign up and complete the remaining level 3, take am2 and then that completes the nvq.
if train4jobs change me onto the full scope level 3 (which is what I thought I was on from day 1) then it will be a different route altogether.
is that above correct?
The 2365 level 2 only has 1 unit you can map over to the 2357 level 3 and that's H&S.
You need to complete the full level 3 2365 to bridge every unit over to the 2357, and then you'll have just 1 unit to complete.
If you do the 2365 level 2 and then enrol onto he 2357 which is level 3, you will have to do every unit of the course as the 2365 level 2 is worthless.
Here's your options
Option 1
2365 level 2&3
2357 (1 bridging unit to complete)
2382 (regs)
NVQ3
Am2
Option 2
2357 (apprenticeship includes the NVQ,Am2,2382 and 2394/5)
Sent from my iPhone using Tapatalk
Yes it is true as it states you're doing the level 2 and 3 2365, once complete you can enrol onto the 2357 and complete just 1 unit converting the 2365 to 2357 and then it's just the NVQ and Am2 to obtain your gold card.
Ok so if what he says is true (to be confirmed once they decide what course I'm actually doing) I would just have to do 1 unit to complete gain 2357? What is this unit? How is it achieved? Is it a new course?
I apologise for asking so many questions. The whole framework and different routes I s difficult to understand unless your used to dealing with them
If you complete the level 2&3 2365 you can convert it to the 2357 and complete the bridging unit " Renewables unit" and then NVQ3 and am2 to complete the course
Your email basically says you have enrolled on to the following courses.
2365 level 2&3 technical certificates
2382 17th edition wiring regulations
2394/5 Inspection and testing
Ok and passing that means I can defernately do the bridging unit to gain 2357, then am2 and then nvq?
what does technical certificate actually mean? Is it the whole level 3 or just part of it?
Once you've done the level 3 (2365) you can then do the bridging unit to complete the technical side of the (2357) you'd then have to do the NVQ and am2 to actually get your certificates.
Technical certificates are basically the college side of the course, like the science etc.
Yes it would be a full level 3 course. You just need to decide what route you're going to take. Oh and the 2357 you'll need employment in the industry to complete the NVQ side of it and you can't do the Am2 without the nvq3 either.
Ok so I can use that email as another piece of proof that Iv been told I'm doing level 3 and not level 2.
i will print off and take with me to the meeting with citizens advice
Out of curiosity how long is the course?
It says you're doing both level 2 and 3.
