Currently reading:
Guidance needed on courses etc
Discuss Guidance needed on courses etc in the UK Electrical Forum area at ElectriciansForums.net
gazdkw82
Hi everyone,
You may or may not be aware of my situation so I’ll explainas simple as I can.
I signed up for (what I thought)was a course which would enable me to become an electrician with train4jobs in December.I’ve done 11 assignments and now Iv since found out it’s a level 2 that ivsigned up for. This was not explained as a level 2 I was told it would make mea qualified electrician (which I have since found out is only achievable bydoing level 3)
So I am in a situation where I:
  1. Changethe course to a level 3 with train4jobs total cost 7k.
  2. Dothe current course I’m on (5k cost) and then find somewhere else to do level 3.Is it that simple?
  3. Leavethe course entirely and go somewhere else (evening college etc) iv rang mylocal college which is Leicester and its 2k for level 2 and 3k for level 3.
    Please take intoconsideration I am 33, 2 children ,partner and a mortgage so I cannot leave mycurrent job
advice would be appreciated
Firstly, how did you sign up for your course. Is the mistake obvious that it was your fault, or is part of the blame with the training company?
This is something I am having to push. I was told by the guywho signed me up that I would be an electrician. He also showed me the picturesof recent refurbishment that all nvq students did to become qualified. He alsogave me a card which enables me to have my first attempt at AM2 paid (the ladyon the phone said she knows nothing about such a card and the AM2 is only partof level 3 which confuses the matter even more)
I feel I was misold which I will fight but the situationstill stands
So they have responded and said that it clearly states in all my documents what course I am on. In fairness it does, however my point is, the guy was in my house explaining the course to me. What he explained and what I have are different things. He didn't once tell me there was 2 courses available. That's the point. I'm not sure where I stand tbh
if im stuck then I'll have to just do it. Apparently I can do a brushing unit 2357 when Iv completed 2265 level 2. If I do the bridging unit and am2 then I can get full framework. Apparently
The only unit you can bridge over from the (2365) level 2 is H&S. You'd still have to complete the level 3 (2365) which then would allow you to bridge every unit you have already covered,but you'd still be required to do the renewables assignments and exam on the (2357) before doing the NVQ and AM2. Hope this helps mate.
Ok so in simple terms what does that mean. would I need to find an employer to complete all the other necessary units to gain full qualification?
Ill try and attach a response I had from my train4jobs. It may help understand what I'll have
http://i125.photobucket.com/albums/p64/gazdkw82/5DEE8325-6448-4E55-8505-3B576296C34A.png
Complete level 2&3 2365, find employment and then enrol on to the 2357 complete one bridging unit ( renewables ) and you'll have all the 2357 technical certificate and then it's just the NVQ and AM2 to complete the course and actually receive your certificates.
Oh and you'll also depending on your age and GCSE result have to do functional skills in maths,eng and ict
You'd have the relevant technical certificates to work as a sparky but defined by the JIB you'd still need the NVQ and AM2 to obtain your gold card.
All I can suggest is once you've got the level 2 start looking for work as a mate to gain site experience while doing the level 3.
Just to keep you all updated. Train4jobs have not responded to my last email which included the breakdown of my course for which I was given at the time I signed up. It clearly states im doing level 3.
I a contacted citizens advice and I have a meeting with them next Thursday
See what he CAB say. Good luck.
Hi
I understand your frustration but you will have to separate your dealings with train4jobs from the exam requirements to progress to be a competent electrician.
The bottom line is that completion of the 2365 Level 2 will not put you anywhere near being capable of progressing to and passing the AM2 or being able to complete the 2357 bridging unit (you will not have achieved the guided learning hours or have the necessary exam passes)
If you are not already in the industry or have a current background in electrical work you are probably on the correct course (notwithstanding the miss selling) , I already completed an electrical apprenticeship many moons ago and have had to go back to the beginning to take the level 2 again (I needed the refresher!)
It is all fairly academic whether you are on the Level 2 or Level 3 as there are units which are necessary and core to both courses which have to be completed. If you do not complete the relevant unit at level 2 you will simply have to complete it at Level 3. If you enrol on the 2357 you will simply complete the same academic learning. The units are are just different paths to achieving the same goal. L2 is an introduction for those with little or no experience, L3 is for improvers and 2357 for those working in the industry (Apprentices etc).
This is why there is a bridge from the 2365 series to the 2357 as many of the core units are the same.
As an example the following courses have cost me with a competitively price training company £5595 and are broken down as follows. This is the minimum path to being a full scope electrician (with a lot of on site experience added of course!)
L2 2365 £1600
L3 23657 £1800
2357 Conversion £1200
2382 (15) £400
AM2 £595
Have a look at the scheme booklets to understand where the crossovers are.
http://cdn.cityandguilds.com/Produc...02_L2_Diploma_Qualification_handbook_v1-5.pdf
http://cdn.cityandguilds.com/Produc...03_L3_Diploma_Qualification_handbook_v1-3.pdf
I hope I haven't been the merchant of doom and gloom, http://www.thompsontrainingltd.com/ who I have used are very good and their website has a good breakdown of relevant courses and pathways, perhaps give them a call if you would like some advice, distance learning and training days may suit your personal circumstances.
as far as I was aware I could finish this level 2 (2365) and the other few units on level 3, then do the bridging unit for 2357 which will convert 2365 into 2357. Then I can sign up and complete the remaining level 3, take am2 and then that completes the nvq.
if train4jobs change me onto the full scope level 3 (which is what I thought I was on from day 1) then it will be a different route altogether.
is that above correct?
The 2365 level 2 only has 1 unit you can map over to the 2357 level 3 and that's H&S.
You need to complete the full level 3 2365 to bridge every unit over to the 2357, and then you'll have just 1 unit to complete.
If you do the 2365 level 2 and then enrol onto he 2357 which is level 3, you will have to do every unit of the course as the 2365 level 2 is worthless.
Here's your options
Option 1
2365 level 2&3
2357 (1 bridging unit to complete)
2382 (regs)
NVQ3
Am2
Option 2
2357 (apprenticeship includes the NVQ,Am2,2382 and 2394/5)
Sent from my iPhone using Tapatalk
Yes it is true as it states you're doing the level 2 and 3 2365, once complete you can enrol onto the 2357 and complete just 1 unit converting the 2365 to 2357 and then it's just the NVQ and Am2 to obtain your gold card.
Ok so if what he says is true (to be confirmed once they decide what course I'm actually doing) I would just have to do 1 unit to complete gain 2357? What is this unit? How is it achieved? Is it a new course?
I apologise for asking so many questions. The whole framework and different routes I s difficult to understand unless your used to dealing with them
Once you've done the level 3 (2365) you can then do the bridging unit to complete the technical side of the (2357) you'd then have to do the NVQ and am2 to actually get your certificates.
Technical certificates are basically the college side of the course, like the science etc.
Yes it would be a full level 3 course. You just need to decide what route you're going to take. Oh and the 2357 you'll need employment in the industry to complete the NVQ side of it and you can't do the Am2 without the nvq3 either.
Reply to Guidance needed on courses etc in the UK Electrical Forum area at ElectriciansForums.net
