T
thomas-1981
Hi All. Has anyone used GX53 downlights? I'm struggling for depth in a lowered ceiling and seen semi recessed gx53 downlights. I would be using the 13 watt lamp. Apparently these lamps give of the equivalent of 60 watt halogen. Thanks in advance. Thomas
I have not fitted them I have only seen them used as under cabinet lights, but those were 9W. I would not have said that they were as bright as a 60 watt halogen, maybe a 25W. They should be OK as downlights since 13W strip lights are quite bright, so long as you have enough of them.
The lamps are not so easy to get for customers but they should last better than halogen downlights.
Being slightly non useful I have seen various LED downlights that are quite shallow and these may also be suitable, but I cannot remember which ones:disappointed:.
Hi, I fitted 6 in a kitchen with a similar problem as you are experiencing. They provided the main light and were very good, slight warmup delay on switch on, they were not 9w but cannot remember what wattage they were 13w? they were made by aurora
Hi,
I use the gx53 Downlights a lot in fitted bedroom furniture for over bed lighting. The Led lamps for them are very good now, think 7w is the highest available in the Led version, might be wrong though! CPC sell the full range of lamps from sensio
