N
nickblake
Just thought you may like to see what happens when you install halogen down lighters incorrectly , this was found at a local care home 24 down lighters 12 with burnt out cabling and joists which had been on fire !!!! they have now been replaced with Deltec 9 watt 60 degree led down lighters 007.jpg008.jpg
Well on the bright side, they've created a lovely patina on the pine joists, looks almost mahogany or walnut like..could make a lovely bit of reproduction antique furniture with that and a bit of polish & wax.
Most downlighters have choccy block connectors. Even new LED ones. Nowt wrong with the choccy block was probably badly installed. Obviously!
but was that candy floss installed on top of the lights. that would compound the bad fitting.
Ye Daft! .... Who put that joist there
But there is another pro , maybe for installing led down lighters them halogens get hot to . Not saying that's totally to blame hear but it would not have help having that little halogen heater so close !
Crazy to think ppl just don't know or probably care more the case.
Do a job right includes the specification of products tut tut tut
I don't do much domestic. But when I do 7 out of 10 times there is always issues with down lighters. Electricians who connect them up with just connector blocks( open connections) should be SHOT
I haven't been going for long as a business but during the past year I have come across a fair few downlights that are surrounded by insulation. I'd be interested if anyone has any tips for getting rid of it when it is on a ground floor ceiling with no access under the floor boards?
I spend quite a while just slowly pulling out bits or using whatever implement I can to get the insulation out and make sure the correct radius is left free around the lamp and also nothing above!
