i have a fuse box with a 32a ring on it and two 6a lighting on it its in a factory and the ring has a few molding machines on it. this CU has a eaton 40A supply on a 6.mm 4c armored.
now i need to install a 32a spa onto the CU.
im a little worried that with the start up from cold on the spa with 6kw heater and the ring main loaded that the 40a eaton would trip.
ive been looking for a 45 or 50 with no avail so do i just attach and hope it will be ok or do i find another make that will fit?
cheers guys thats all the info i have.
now with diversity and the over rating on the mcb ... ... im wondering.
