Discuss Heater temperature stopping in the UK Electrical Forum area at ElectriciansForums.net
More info required.
As above...
Have you already got your heating element and equipment?
Not that I know a lot about heating elements but these just look like there are different wattage/sizes of heaters. Nothing about heaters that switch off at 70C
Whatever you do, don't just wire a potentiometer in series with your element!!
As said above, you need a sensor/thermostat of some sort. Why do you specifically not want to use a thermostat? This is the sort of job they are designed for!
You can't heat to a specified temperature without a thermostat. (well not quite true you can heat to 100 degrees C as the water just boils off at that)
If you know the starting temperature of the water, the heat loss from the vessel you could approximate the right temp with a timer but that's very rough...
Picking up on @Pat H thought - you could time it to get to 70C (cooking thermometer) and set egg timer or an electrical timer. But thermostat is the most accurate method.
I'm waiting for an answer to this from the OP....
You would need to factor in the starting temperature of the water, ambient temperature of the room.. impossible to be anything like accurate.
So my post #7 offering decent safety advice received no likes, but my crap joke has got 5. It's a crazy world, but I like it :)
and you've had a like off me for your moan post. :p
Wonder where he's gone. Probably down Maplins for a big variable resistor?
What would happen if I wired in a potentiometer ?
The temperature control options I have seen have been quite expensive!
Reply to Heater temperature stopping in the UK Electrical Forum area at ElectriciansForums.net
Wonder if anyone can help out, my experience in heating is minimal. So house I was working in had a circuit for the water heater, which went to a...
I am asking on behalf of a friend who has an outbuilding that he uses as an art studio, the building is fully insulated and is currently heated by...
Hi all, I have an Economy 7 storage heater Dimplex CXL24N - 3.4kW Storage Heater + Convector ( there not available anymore) that dos'nt work and...
Hi. I know this probably isn't the most fitting platform to post this question, but I was racking my brain where I could get an answer to my...
I have taken delivery of an undersink water heater. It is fitted with an RCD on the electrical supply cable which terminates with a euro-plug. I...
