Discuss Heating controls training. in the Central Heating Systems area at ElectriciansForums.net
H
Howard77
My knowledge of connecting up heating systems doesn't go much past a basic combination boiler and stat set up. I'd like a better knowledge as I'm coming up against systems with multiple valves, ufh, solar and wood burners which have very little to do with the s and y configurations. Can anyone recommend me a decent training course?
Print yourself off some drawings and study them until you can draw the wiring diagram out off the back of your hand without the aid of a drawing to reference from, You could go as far as buying a lifestyle pack and building your own little rig at home to practise on. Read up on how two port and 3 port valves work, once you understand how they work and the order of how everything is switched it's actually quite basic. Going on manufacturers training days such as the Honeywell one is generally a waste of time IMO and you won't learn much.
Here is a course I found but the price is ridiculous but it would probably be more in depth than any manufacturer training.
Central Heating Controls Training Course
I find the simplest way to understand whilst studying diagrams is to think of all the components being switches, place them in the right order and it usually works !
Reply to Heating controls training. in the Central Heating Systems area at ElectriciansForums.net
I've always thought I was quite good a wiring heating systems, I can do Y plan, S plan, UFH set ups, "normal" thermal stores etc, you name it and...
Up until now I have steered clear of heating systems. I now have quite a bit of work with a builder and will be expected to deal with the...
Hello, I hope you are well, I have fitted a few Nests but only to Combi, S and Y plan systems just been looking a job where I’m doing the kitchen...
1 - Major supply fault, details unknown. By time I get there DNO already put in genny and are digging up road. 2 - Reason for call, heating not...
Hello , I’m trying to further my knowledge into UFH/Rad/HW valves heating systems with air source pumps. What is normally needed outside with...
