B
Bill67
have a heatmiser uf8 and originally used 5 outputs number 1-5, I then found output 1 would not work properly so i transferred the wiring to number 6
I have Neo air V2, so first i Disabled the failsafe on output 1 to prevent it hopefully from sending a boiler on signal because there would be no Neo air addressing this output.
I re addressed the Neo air to out put 6 and all seemed ok but output 1 still comes on every hour for 10 minutes because no Neo air seen, even though i changed the default to disabled on P3 to 00
I even tried changing the base address of the UF8 to another number for all the Neo airs but the output still switches on !
I tried the helpdesk but they said what i did should work but it didnt,
Anyone know how to disable that output from looking for a thermostat that no longer addresses it
