Discuss Height of consumer units in the UK Electrical Forum area at ElectriciansForums.net
Charlie_
I always install my consumer units between 450 and 1200, sometimes at 1400..
Am I right in thinking that CUs come under part M?
Extensions and rewires not covered by part M?
Anybody still installing them up at ceiling height?
On refurbs I normally get the customer to decide ......... but certainly not at Part M heights ............ they are simply daft
new installation, you and the client have choices. on a replacement CU, you need to fit it wherever you can considering the existing supply and final circuits.
Is it even in part M because I can’t see it?
It’s mentioned in part P as a guidance for the height of a CU but I don’t believe it’s actually a building regulation unless someone can show me different?
We are required tho on new builds to mount the CU with the mcbs at between 1350-1450 FFL.
I believe the idea with not installing lower than 1350mm is to prevent small inquisitive children from getting access to it and playing with the switches. I’ve read that somewhere.
I think the 1350 is a good height if it can be achieved easily enough.
Very high consumer units are not ideal. Earlier this year I had a concerned daughter call me because her rather petite and elderly mother was climbing stepladders to keep resetting a breaker for a faulty water heater. Not good.
3C34AFA2-3A77-4154-B632-270E9F6487FA.jpeg I’ve spoke to my LABC officer regarding this on refurbs/rewires and his stance is that when rewiring you should not install accessories at a height that is worse than compliance, than it was before you started. For example say the existing sockets are mounted at 300 then you install them at a height off between 300 and 1200. So you wouldn’t then go and install them at 250 as then they would be installed at a height that is worse than compliance, than before you started.
Thanks for the responses.,
Had a few occasions lately where the builder grumbled at the height of 1400.
Another new build cu went up high at ceiling height, fortunately building inspector didn’t pick up on it, I thought it was best not to ask him about it.
I think the 45o height would be handy as it can be located in a cupboard
Usually see them at ceiling height over here. Was in 2 today, one built in 2014, one in 2016...both at ceiling height. On large developments as well...
Similar situation over here;
Large development, CUs in hallway above lounge door, looks naf but was probably the best location to facilitate a 2 day 1st fix.
There is a whole new build estate here with them all at ceiling height in the garage.
Another estate a few years ago they are above the basin in the hall toilet.
seen loads of them. need to stand on the bog to reach. cubicle too small to fit steps in.
Reply to Height of consumer units in the UK Electrical Forum area at ElectriciansForums.net
I am installing a 14KW ducted aircon unit in a single phase house, which requires a 40A breaker. I was thinking of asking the electrician to put...
Hi all. Customer asking me to fix 3 phase consumer unit on a new shop . Its brand new installation . He want to use every part of shops and he...
Hi all, what is the best way to configure surge protection in domestic dwellings when you have multiple consumer units? Does each consumer unit...
4K
