Discuss Help!!! Can't turn electric off!!! in the UK Electrical Forum area at ElectriciansForums.net
I'm just wondering why there's a red and brown wire coming from the service head going to meter and why is there a grey sheathed cable into the earth Henley block? Where does that go?
Believe or not the brown tail is the neutral by the looks of it. Incredible!
The grey tail is the TN-C-S link between earth and Neutral even though it is also set up as a TN-S. I’ve seen this twice before.
This reminds me of the time I got a nasty belt whilst changing a socket in a flat.
I switched off at main switch and my radio went off in the kitchen.
That was the amount of dead testing I did. LoL
I then took socket off wall in lounge and got a belt. Wtf.
After checking the precious tenant had drilled a hole through the back of the service head and passed a 2.5mm from service fuse to busbar feeding one of the breakers. Bypassing the meter completely.
This obviously left the whole busbar and therefore any breakers in the on position with voltage outgoing on the live conductors but turning off the main switch would cut out the neutral leaving nothing working in flat giving the impression it has been isolated.
I put it down to someone growing or for some other reason trying to extort electricity.
Reply to Help!!! Can't turn electric off!!! in the UK Electrical Forum area at ElectriciansForums.net
Is blue neutral or earth when there is a black cable (which is the old neutral) - old system? Other one is red, no green / yellow
Hi, I'm looking to install a new bathroom extractor fan in my bathroom as I have a windowless bathroom and the current one I have installed in...
I am trying to understand how a relay system works and have designed a circuit and a ladder diagram all as attached for an 8 PIN relay, a current...
