and why not the service head Tel....its a once only chance to see if it really is tncs....or not....bash the bugger in with a sledgehammer. (the rod, i mean, not the service head)
PFC should give the game away though TCNot necessarily i have seen this before and found it was TN-S (when the fuse carrier fell out and the cover over the neutral fell off!)
As long as the other flats have a similar setup (with the earth coming out of the service head) and your neighbours have the same then its fine to dig up - its probably from when they built your house or a neighbours house in the first place.
Little hint these are at least 1 meter long usually 2 meters long (if 2 joined togeather.
If you cant pull it out get a digger - tie a rope around it and pull it up - or dig around it and cut the top off with a grinder or hacksaw then berry it again.
With this system its fine Skewiff - if your flat has not had its electric checked in 5 years then its worth getting it checked anyway
well when the electrician comes round...he will be doing a Ze anyway....this will confirm the earthing arrangements you have....and whether its good...or not...
