Discuss Help new kitchen nightmare in the UK Electrical Forum area at ElectriciansForums.net
...Looks like a pretty common attempt,where the electrical part of your project has taken a lower priority on your contractors' list...
I genuinely feel for the OP.who probably went through the process of getting quotes,and assumed all players read from the same hymn sheet.
See this,and much worse,every month. Last one was an impressive,and expensive two-property rear orangery,bi-folds and feature log burner...the works. The door to the kitchen,opened in to the addition,and a cupboard/shoe store had been built on the lock side.
A double S/O had been fitted on the side of this,30mm pattress,cables in cupboard in trunking...all neat...until you plugged something in and tried to open the door...
Owner had asked my opinion on this issue,although several rational options were apparent...someone needed punching :icon12:
Shoddy lazy work. I feel for the OP as they should give the, ahem, electrician, cough, splutter, the chance to rectify the issues. But I would not want someone like that anywhere near my house ever again. The grey cable is not heat resistant and I doubt the white flex is either. So shoddy work and a liar. And I hope the hob is gas with electric ignition!
More photos as others have suggested. May be worthwhile talking to another local electrician expressing your concerns and seeing if they can spend an hour to give it a visual check over.
GOOD LUCK!!
Caveat emptor: Employing a kitchen fitters to carry out other trades is a recipe for disaster.
The law provides for recompense against poor workmanship. If the OP is aggrieved only he can take it up with the kitchen fitters.
Hi.people sorry late reply just back from work to let the electrician in to apparently put things right
We paid half the money before work started. We are supposed to get certs when we pay the remainder.
Update so the electrician has just been round again and has put trunking around the cables and moved away from pipes a bit and tidied up the cables strewn across the loft. Although I haven't looked too close and will post some pictures later.
Our other worry the hob and oven just on two 13 amp plugs to the wall. He just baffled me with numbers and when I said. I don't see plugs mentioned in the installation manual He said its because people would try and plug them into light circuits. I replied I've never seen a light switch with a plug socket in it and why wouldn't they just plug it in the wall anyway. But then got swamped with techno talk
i really appreciate all the kind responses and will post back later when we are home
thnx all again
thnx all again
Have you got the make and model numbers for the oven and hob?
as above, or can you read off the KW rating on each?
The first thing to ascertain is, ...is this a particularly rough qualified electrician, or a DI (Domestic Installer) that at best has been to a training center for 5 Weeks or at worst , for just 17 days??
My guess is the latter, and a perfect example of why these chancers should not be allowed into people homes....
Anyway what are you, or should i say, how far are you prepared to go to get your electrical installation back to a reasonable expected standard??
How about posting a few more photo's of what you are considering not up to scratch or indeed dangerous...
Here's a couple more pics top and bottom going up wall into loft.
Also worryingly I think for us the hob and oven are electric they are Lamona side control hob. Lamona fan assisted oven. LAM3301. Will post pictures later
We will be giving him a chance to out things right. But are still very worried about and would appreciate all comments.
thnx
This has all the hall marks of a kitchen fitter doing the work and a spark coming to test and sign ofF. Done lots by very established sparks from my experience.
thnx
no pics!
Reply to Help new kitchen nightmare in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm installing a Hoover oven and would like a little help please. The oven code is HOC3158IN. The oven manual states "The power cable must...
Hello, Last year I had some electrical work completed in my house (New CU, SWA for garage, downlights) I informed the electrician that I will be...
Currently planning a new rewire for my kitchen and want to get things right first time when it comes to appliances consumptions and circuits...
