Discuss Help please - Is this acceptable? in the DIY Electrical Advice area at ElectriciansForums.net
Can you sketch the layout. I know you say it's a small kitchen but it is where the most appliances live. Four sockets sound inadequate. Talk it through with your spark send him a nice piccy with the layout.
If you have two fit 2 X 2.5 t+e in say 1500mm of 20 mm conduit as long as the cables are straight then they will fit easily with no lube in sight
I agree if the tube is fitted to a wooden wall in a classroom. Lost count of the number of rewires I was involved in, where the buider has jumped the gun and stuck some conduit in and plastered over it, "sparky can get his wires up there no problem"
Shot run in a straight line not a problem perhaps your not gentle enough
How many dead straight runs have you come across in tube chased in and plastered over, only takes a little curve or deviation to spoil your day imo.
No problem with this
In fact you could go one step further and run in the cables to the various points and take the legs back to the board
Ready for the sparks to connect up
Youll have the union reps on you for that one.
How will the "Sparks" be able to be sure the cabling has been installed correctly, and sign it off as satisfactory? this is a kitchen.
Pull it out, have a look and pop it back, if he's inclined to do so, I doubt he will be though.
If the job is small and as simple as the OP states then a cooperative, busy Spark would be only to happy to assist in making easier for all.
Some of the miserable old curmudgeons on here are a different story though.:p
Just done that on a job, 20mm conduit straight into boxes, builder dot n dabbed over, plastered, then I cabled ready for 2nd fix.
Good luck getting 25mm conduit into your backboxes.
Reply to Help please - Is this acceptable? in the DIY Electrical Advice area at ElectriciansForums.net
Doing some work in a commercial restaurant/kitchen the builders had already boarded and plastered the walls meaning my only viable route is to use...
Grateful if someone could offer some advise, I'm struggling to find a definitive answer to this. I have a double socket, it was on the ring main...
Hi there - good site. Mrs wants a new socket directly below a light switch on the ground floor (says it will look neater vertically inline)...
