Discuss Help please - Is this acceptable? in the DIY Electrical Advice area at ElectriciansForums.net
Hi,
I am currently doing a small kitchen. It needs to be wired, however the elctricians can't do it for a while, so what im thinking about doing is chasing out the walls and putting in 25mm round conduit, then plastering over it, so when the electrical work can be done they can just push the cable through the conduit and to the sockets. Is this ok to do? It's only for 4 sockets, as it's a very small kitchen.
Thanks for reading.
There's nothing to stop you from installing the first fix as an unskilled person. (Unskilled as in not an electrician). It might be worth just getting a sketch for a suitable conduit layout from the sparky who's scheduled to do the installation at a later date.
I'd comment that 25mm is maybe quite a deep chase especially if horizontal unless you don't need a plaster finish on top due to being tiled.
Get the electrician in to look at the job,
he can then decide on the routes for the cables,
then you know exactly where to put the cables.
Find another electrician who can do your time scale, or wait for your first choice.
Hi,
Thanks for reading.
In theory yes it's OK, in practice however not really a good idea, or recommendation as you don't know how the Electrician will wire the sockets, plus it will be a right fiddle getting 2.5 cable into a circular conduit post plastering in my opinion.
No problem with this
In fact you could go one step further and run in the cables to the various points and take the legs back to the board
Ready for the sparks to connect up
How will the "Sparks" be able to be sure the cabling has been installed correctly, and sign it off as satisfactory? this is a kitchen.
Text them to ask if they are happy to proceed
Take a few pictures on your smart phone on job in stages
Show them when they come to connect up
No problem
Hi,
Thanks for reading.
I'd use 20 mm conduit myself
I wouldn't bother. You'll bound to miss or forget something. You wouldn't start installing some kitchen furniture 'cos the installers not available.
You should just wait as others have already said; have your kitchen installer come up with a suitable 'timeline', with dates for all the trades to attend.
20MM tube buried and plastered over, trying to get 2x2.5mm T and E in? good luck with that.
The cables would require some serious greasing up but doable over short lengths
25mm conduit would be much easier
Reply to Help please - Is this acceptable? in the DIY Electrical Advice area at ElectriciansForums.net
Grateful if someone could offer some advise, I'm struggling to find a definitive answer to this. I have a double socket, it was on the ring main...
Hi there - good site. Mrs wants a new socket directly below a light switch on the ground floor (says it will look neater vertically inline)...
Help please! I need a Tesla Gen 2 EV charger fitted in my garage which is 22m from the consumer unit. My electrician is proposing to route a 6mm...
Hi all, I am planning to install wall lights such as these ones (LAP Bronx Outdoor Up & Down Wall Light Black - Screwfix -...
