Discuss Help regarding a Horstmann Electronic 7 timer in the UK Electrical Forum area at ElectriciansForums.net
Fieldy618
Hi,
I'd like some help on an issue I'm having with my Horstmann electronic 7 timer if anyone can help me please. Our electricity bills currently seem very high for this time of year, they're coming out at £80 a month for a 2 bed apartment, with both me and my partner being out between 08:30 and 17:00. I figured that the only thing that could be causing this must be the water heater tank.
I looked at the settings on the timer and it looks like it is set to come on between 03:00 and 06:30 which seems fine. However when I change the hours the off peak light only comes on between 07:00 and 11:00? This can't be right surely? Does anyone have any experience with this model?
Thanks,
Benjamin
Not sure I follow what you mean by turning off the breaker? Thanks
Fieldy618 in the USA we have hot water tanks with immersed heating elements which I have a 50 gallon tank 30 amp 220vac breaker feeding it, and I just disconnect the power. I’m not quite sure what is being used in the UK but I would assume it has some power going to it and that’s what I was referring to
The tank should have two elements.
Top element should be wired to the peak supply and be timed on for an hour or so if needed or used via the boost button.
The lower element should do the majority of the work and wired to the off peak supply which SHOULD come on over night.
A non-contact voltage indicator will suffice to confirm yours is set up correctly.
It seems your off peak times are not set up correctly. Hopefully ive attaced the correct user guide.
  • Horstmann-User-Guide.pdf
Hi, thanks for the attachment, I've seen that manual already and used it to change the timer in the morning but I still don't understand why in the video I attached the off peak light only comes on at between 7-11am and not through the night?
I can only think that the off peak settings are set for 07:00-11:00.
You may have thought you were setting the off peak but actually set the boost.
Without running through it myself, which would be long and ponderous, i cant see what else it is.
Reply to Help regarding a Horstmann Electronic 7 timer in the UK Electrical Forum area at ElectriciansForums.net
Hi All, I have been having an odd issue with My Horstmann Electronic 7. It had been working normally and then I found that the display had turned...
4K
Hi, We have just moved into a new flat with the old Horstmann electronic 7 timer for our immersion boiler. We just moved from a flat with the...
5K
Hi all, Yesterday I returned home to no hot water after a few days away. After a brief inspection it seems the fault lies with the Horstmann...
4K
I am in a bit of a pinch at the moment and trying to argue a massive amount of used of electricity with my provider which I find it hard to...
Hi all, As an electrically illiterate person I've found a lot of the posts on this forum helpful when fixing things round the house. I was...
12K
