Discuss Help with a question (R1+R2) in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
N
nutmeg1975
Hello all,
I hope someone can point me in the right direction.
Come across a question today that i am not sure on the answer to.
"What multiplier do you add to R1+R2 to all low temperature increase under fault conditions".
I am not looking for someone to answer this as want to figure this one through myself if possible but would like some help to be pointed in the right direction.
I am thinks along the Ze value or K value.
Any pointers would be very much appreciated. Thanks
Hello all,
Ok as you want to go for it yourself - Onsite Guide Table 9A P166
Good luck!
Warren
Reply to Help with a question (R1+R2) in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi forum, A question about R1+R2 testing. I’m testing a lighting circuit. It’s an old circuit with old colours. In the control panel feeding the...
I have been going round in circles with this question. I just cant seem to get an answer remotely close to the options. Continuity of a ring...
Hi Guys, sorry if posting in the wrong section. I am due to start 2391-52 course soon, and there seems to be from what I have found out, a 3 phase...
Hi All, Just looking for some advice: I'm in the process of updating an old cable calc spreadsheet that helps to spit out Zs and Voltage Drop...
Got my am2 coming up on Tuesday and I know I have to calculate my Zs readings Maybe I’m overthinking this but am not sure if I need to use the Ze...
