Discuss Help with Dryer Wiring in the Electrical Appliances Forum area at ElectriciansForums.net
sano888
Renter bought a new dryer because the old one wasn't heating. New dryer did the same. Returned it. I checked the plug, 124ish at the ground and hots, 240ish between the hots. Next dryer same problems, dried the first load but not the second. Checked outlet, red wire didn't read properly. Replaced the outlet. Tested fine but then didn't. 10-3 wire runs to a 30 amp breaker sub panel which runs to the breaker box. Lines read correctly out of the sub panel. Is it possible the line from the sub panel to the outlet is somehow bad? What am I missing? I am an amateur so speak slowly.
My friend when the dryer is replaced then you have to install a 4 wire cable. 2 hots 1 neutral and 1 ground.
Reply to Help with Dryer Wiring in the Electrical Appliances Forum area at ElectriciansForums.net
Hi all. DIY here. Electric Dryer (Kenmore Dryer - 796.61552.610) had been tripping the breaker sporadically over the past few months. Recently the...
I recently purchased a rural property in Arizona. The property receives power from APS, the local electric utility. Power arrives from the...
I am totally new to fixing things but with the help of YouTube I think I've diagnosed my tumble dryer, now, I'd just like to know what others...
I have a 3 prong 240v outlet for a dryer that reads 240v across both legs and 120 across the ground. When I turn the dryer on and have the multi...
I’m running wires to the basement for future basement finishing. I’d like to add two circuits of outlets (one on the finished side and one on the...
