Lead covered cable (Mackintosh cable?).
Recommended for a 25yr normal service life.
Strongly recommended for replacement after 30yrs
The cable has not been manufactured for at least 50yrs
And i am still finding it in working installations?????
Just goes to show that the old lead and TRS cables were pretty dam good for there time!! lol!! It was only ever the tails that that became brittle, and that was mostly due to the heat baking them from incandescent lamps, or overloading sockets etc!! Think i have mentioned before, i used the old TRS cable i stripped out of my parents house during a rewire, and used it in the garage. Apart from the ends at the wall accessories, the cable was as good as the day it was installed. And better suited for a garage install as it's immune to cold and freezing temperatures ...Unlike our modern PVC cables!! lol!!
couple more pic's and a heads up for the younger sparks take a close look at the consumer units , incoming supply fused neutral and live and also the out going fused neutral and live , and here's the warning and what to look for , between the fuses is a plate of asbestos ,also behind the fuses of the small board pictured below is also asbestos so if you come across this type of board be careful and of course the good old wooden one too View attachment 17709View attachment 17710
Tut, tut.....such a brill job, but where is the fusebox labelling ?
:cowboy:
