Discuss here's a drill ! in the UK Electrical Forum area at ElectriciansForums.net
telectrix
Mentor
picked up this morning at a car boot. £20.
Nice find . i used to have one years ago , you will find 2 sets of pulleys in the top with a belt you can move for different speeds as well.
find yourself a good vice to bolt down and you're away...
Can't go too far wrong for 20 quid. They're not too bad for light home-workshop/DIY use. They sell a similar 1/2 HP Ryobi one in most of the tool places around here which is the equivalent of about 40 quid brand new. I never figured out how they can sell them so cheap, even to buy a generic 1/2 HP single phase motor costs more than they charge for the entire bench drill.
Be careful of the start switch. I've got the same drill, and it sticks in quite often. Need to jiggle it a bit to allow it to release, otherwise the stop switch has no effect at all !! Good drill though for the money. Daz
Reply to here's a drill ! in the UK Electrical Forum area at ElectriciansForums.net
Hi I've inherited a very tight space, a KMF switch and some split-con for a sub-main to try and tidy up. It's a joyous non-restrained single...
I'm installing smart modules in my light switches which means I need to replace the existing 25mm back boxes with 47mm ones. Downstairs all walls...
So I had a ceiling repair done in my bathroom due to water damage. The neighbors toilet above me was leaking for who knows how long. Mold...
Hi all, as in the picture, when connecting a 230V cable to a db like this, is there a legal requirement to install external RCD unit? Also, if the...
