Discuss Hi All. 1 gang & 2 gang 35mm back box in the UK Electrical Forum area at ElectriciansForums.net
Has anyone used or fitted this type of back box ? It is a 1G & 2G
Use them quite regular in kitchens where you might have a double socket, and an isolation switch for a below counter socket.
Switch and socket are butted against each other with no gap, but can be tricky if decorative fittings are used that are slightly wider than standard white.
Also come as 1+1 versions as Westy mentions a dual box.
Yes, they're fine, and useful. For some reason there are only 2 (diagonally opposite) fixing holes, but you can always drill more if one or both of them line up with crumbly substrate. None of the lugs are adjustable, so you have to get the box spot-on level.
Always wondered why this was the case with dual boxes - shouldn't be a great hardship for manufacturers to place adjustable lugs on either side.
Reply to Hi All. 1 gang & 2 gang 35mm back box in the UK Electrical Forum area at ElectriciansForums.net
Hi all, I am an experienced DIY electrician and I just wanted to ask a quick question about something since I am new to this forum, if it hasn’t...
Is there such thing as a 2 Gang flex outlet plate, changing an existing heating system to a nest so no need for the programmer however it is by...
Hi, I swapped a 2 gang switched socket for a 2 gang switchless socket with usb ports downstairs. I switched off all the power to the house by...
Hello everyone, Following on from my previous post where I received advice on taking a spur off a 40a feed (thank you). I performed the work...
Hi all, This weekend we have a selection of essential items for Sparky's on offer! Wago 221-412 2 Pole Compact Lever Operated Connector -...
