E
EricMark
True, and not sure what percentage of Hive would be required? Two Hive TRV heads same price as extra Hive wall thermostat so if combining zones can use single Hive wall thermostat with two Hive TRV heads in the critical rooms, the much cheaper eQ-3 TRV heads will stop rooms heating but will not tell the Hive wall thermostat to switch on, so question is how many Hive and how many eQ-3 are required to control the home.They aren’t Hive though are they?
Personally I would start with one Hive TRV head in coldest bedroom and Hive wall thermostat in main living room and test it out, if rooms are warm enough then all it needs is to reduce temperatures in rooms when not used by fitting eQ-3 heads.
