DJMElectrical
Hi All,
This may be a silly question, but i have been to look at a job for the installation of a hob extractor fan. My question is the recommended maximum duct length for the extractor is only 1.5 metres and i need to duct it about 4 metres out of a tile vent. Is it possible to just fit another 4 inch inline fan half way along the ducting and connect it so that it comes on with the hob extractor switch fuse spur?
Many Thanks
Dan
Cant see why not, but would be better if it was switched by the hood fan.............might have to use a relay/contactor depending on the hood switching.
Why not just see how we'll it works without the extra fan, you may find its good enough.
No harm trying
as kevin says. wher does this 1.5m come from? is it a bungling ( sorry building ) reg?
You need to establish why the 1.5m guideline is there before you make adaptions, it could be because the oils/fat in the steam effectively cool down and would build up in a longer length this would also clog the in-line fan up.
Im not saying this is the case but a call to the manufacturers technical will give you a deeper understanding, you need to be aware the 1.5m has been specified as its manufacturers instructions and part of the 17th means you need to comply with this; if you do deviate from the regs then you need to show you have done so with understanding of the manufacturers limitations and also show your adaption wont create any issues.
I would show scepticism at any post that premotes that you do it without a knowledge of why the max length has been implicated in the first place.
the reason for my post. is the 1.5m a manufacturers recommendation, or something dreamed up by faceless bureaucrats.
I hadnt seen any replies upon writing as i took a call and when i posted 3 replies were on already i was pre-empting anyone suggesting its ok and as i read yours tel its clear you are also questioning why its there and a need to find out first.
Never seen this 1.5mtr reg, if there is one many millions of extractor fans and namely cookers are in the wrong place in this country.
It's most probably just that the fan won't reach its stated performance with longer duct. As KevinS says, I'd install it. Use large bore ridged duct with smooth walls, either round or rectangular, and keep the number of bends and restrictions to a minimum.
the crap fans in hoods are next too useless at shifting air the hoods have a crappy filter built in
just put it on re-circ no ducting needed
job jobbed
DJMElectrical,
ayjay,
