Discuss Horstmann Control 37 in the Central Heating Systems area at ElectriciansForums.net
CubeRoll
Good evening to All,
Hope all is well.
What I would like to know is if possible to run all 3 channels at once, on same timings. Heat upstairs, Heat downstairs and water heater. It's a sealed system, pressurised. Unvented tank, 180 litres.
At the moment, water comes on, heat upstairs comes on, but downstairs heat doesn't until one of the others is switched off. Is there a fault with wiring or not possible with this system.
Thanks in advance for any advice
Reply to Horstmann Control 37 in the Central Heating Systems area at ElectriciansForums.net
Hi, Small flat, currently has a small'ish feed water tank, top of a cupboard, feed through a wall into under stairs cupboard. Hot water tank...
1 - Major supply fault, details unknown. By time I get there DNO already put in genny and are digging up road. 2 - Reason for call, heating not...
Hi all, I have a slightly mish-mash heating set up, in that downstairs I have wet underfloor heating with an individual thermostat per room, but...
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
