house supply 100A tns 32A mcb feeding garage(10mm swa buried ) 100A board.. currently with lights on 6A and sockets on 20A ....customer wants massive hottub installed in garage ....problem is manual says requires 2 x 32 A supply for tub ........any suggestions ?
So would any of you install this ..or tell customer he needs new supply
Yeah, as said in a previous post. Tap off the mains supply from the house with a switched fuse unit and supply it like that.
If they want it installed it can be done. There will be definitely be a little diversity to be applied, it won't take the full whack.
Yes I don't see the problem that you are obviously seeing
The only issue the customer may have is when it is first filled or filled after a clean which only happens around once every 6 months with the quantity of water specified heaters could be running for couple of days or more to get up to temperature. My mates hottub takes around 1600 litres of water and takes around 18 - 24 hours to get from cold tap temperature to 40°C after a full clean.
The key to low energy use with a hottub is to keep it covered when it is not being used so the heat isn't being lost and keep the pH and chemical levels right so the water changes are kept to a minimum
The insulation on hottubs is quite good and with a cover on lose very little heat as an example a few years ago my mates tub developed a fault the outside temperature at the time was between 2°C and -2°C after 48 hours with no heaters or pumps running the water temp had dropped from 40°C to 25°C
So the biggest problem is likely to be the customer not looking after the water or using the wrong chemicals, chlorine can be very aggressive on the components in a hottub
neath
hot tub in garage (diversity)
scott 123,
UNG,
