Although you don't have to install to the heights stipulated in part m your work shouldn't make it any worse. It appears like it would be much easier to put it lower and run 50 x 100 trunking, depending on the room either chase the wall so you're behind the joist or use an internal 90 to run a small bit on the ceiling.
Dusty might sell you some black and red if you're not part p...
