Discuss How do I safely connect these two? in the Auto Electrician Forum area at ElectriciansForums.net
As seen in the pictures, I need the pigtail style connected to the other style. It needs to be fully weather proofed and safe as this is wiring for a light bar on my Jeep Wrangler. So please let me know how to safely do so, rather than just shoving the two together! Thanks in advance80B6FCDE-5EEB-4027-8F4D-89FA406BE95E.jpeg77D8B64D-6011-49B5-9C67-D605AE3DAFCF.jpeg21BD5BE8-15BB-41E8-88BC-A0087CCCA95B.jpeg
Do they need to be removable? If not then I would cut the connectors off and solder the joints. And use heatshrink sleeving (ideally adhesive-lined) over each joint, and then over the lot. This will be the most reliable and weatherproof method.
If you want it demountable... then as Tel says + some contralube inside it all before you tape it up. If it can be a permanent connection... then I'd do a proper solder joint before heat shrinking it.
Reply to How do I safely connect these two? in the Auto Electrician Forum area at ElectriciansForums.net
I have breaker box at least 40 yrs old, both conduit and romex enter box, only one neutral bar that all white wires and bare ground wires attach...
Thank you for taking a look at my issue. The pictured standing lamp had a foot actuated on/off switch which broke. I would like to join the...
Hi everyone, after temporary removing a Sonoff that I've installed years ago to do some painting, I'm unable to get everything back to work. I've...
Hello, my house was built in the 1950s and every time I look behind a wall plate the wiring isn’t how it’s shown in any DIY book I’ve read. I’m...
