Discuss How do you keep the dust down in the Electrical Tools and Products area at ElectriciansForums.net
steve
Hi lads,
First time poster here so go easy lol.
I have been a spark since 1993 in domestic set ups mainly. 2 year ago my dad passed away with a dust related disease and since then I have really hated dust when chopping out for sockets etc or even worse spotlights in artex ceilings!!! (say no more about that nasty dust) . I have tried the Armeg which was even more dusty even with the hoover attachment and hated using it and seen the D.A.D.E which looks good but not tried yet and the best so far which I have kept in the van is the Dustbox from Amazon which is really good for chopping sockets and also brought the pricey spotlight driller which again takes all the dust away in my little Henry.
What do you guys use for dust control if you do at all? I never used anything till 2 years ago and infact I found the dustbox socket box much easier certainly on 45mm boxes for sure. The spotlight one is great I found.
The one I use is here https://www.amazon.co.uk/dp/B07FTY2CK8
And spotlight box https://www.amazon.co.uk/dp/B07FW81DQG
They sell a single socket one too and a dryline box version but not tried them, has anyone else?
The way its going with me and dust I think I may stick to EICRs!
I use the dade for Downlights and have a chaser and m class vac for tracking.
Multi tool plasterboard walls doesn’t make that much dust, never mind in the air.
Recently on a job where we had the use of a Hilti chaser and hoover.
Very good, much better than the one I used in 2005.
Most of the SDS drill manufacturers now do hoover attachments for their drills.
Other than that, you, you need a mask.
Yes I have a Chaser and works well but rarely use it because the chases are few and far between on my jobs. Again I find the Dustbox set up really good for it and use the spotlight driller to stich drill the walls. Yes I have mask but the amount it needs to come on and off just gets irritating. I'm going to buy the Dryline dustbox today - although it dosent create alot of dust I think in years to come it will come to light how bad that gypsum dust really is. Anyone else?
what's a bit of dust compared with 50 years of B&H 's finest?
Masks are PPE and therefore a last resort.
Dust suppression should be what we aim to do when dust is a significant risk.
just tell the apprentice to keep gobbing on his mobile when chasing. end of dust problem
I notice on the outdoor paving works they always have dsom kind of water feed to their diamond cutter and there's never any dust billowing around, that might only be better than vacuum attachments in some situations where the water wouldn't damage everything else in the process.
A very good mask (suunstrom or similar) worn and as much functioning suction around the chase being made as possible. The mask though, at the end of the day, will give you satisfyingly clear bogeys in the shower when you get home.
nothing is foolproof but you do what you can.
Have a Vacuum on as you chop, and keep using it to limit the dust spreading, also use a good mask, keep windows open and if you use a grinder fit a vacuum to it as you use it, otherwise there isn't much else you can do
Hi - sorry to hear about your Dad.
I have got a DADE and use it all the time. I now also put a bead of wallpaper paste on the area to be cut. Go slow and there is zero dust in the air, IMHO. Wipe it off or wash it into a bucket.
Caption "that hole looks so good, I think I'll cut another ..."
For chasing I use a Metabo chaser with Trend M class vac, plus fitted face mask. When sweeping up I try to damp down the dust as best as possible.
If drilling ceilings is necessary I check the asbestos report, then if anything nasty is present I believe company policy is to suit up, fitted face mask, rubber gloves, dust sheets and H class vac, the the dust sheets are double bagged and put in the asbestos bin at the yard.
I believe some people apply shaving foam to the area to be drilled to catch any falloff.
For me, it's the Makita SG1250 wall chaser, Makita VC3011L dust extractor and Armeg AHC40-200 adjustable hole cutter.
Reply to How do you keep the dust down in the Electrical Tools and Products area at ElectriciansForums.net
A friend of the family recently lost her husband to the big C so I need to be careful. Every small thing is sending her into tears so when her...
I have been asked/invited to "post more", lol, so let me make another post right away. I thought of sth worthy to post, of interest to many, I...
Hi all, Disclaimer: I'm not an electrician and have very basic knowledge of electrical installation. We've been putting in a new kitchen into an...
