H
hozza94
Been dealing with my supplier recently during the lockdown as I got bored, and I started to explore the electrical set up at home as well at the same time
I currently have something call a 2 MPAN Economy 9 meter in the meter cupboard, which has 1 L+N in and 1 L+N out, and an extra blue cable going into covered metal trunking. I live in an apartment building so the trunking is in a communal cupboard. No other neutral contact or henley block that is visible as far as I could see.
In my flat, I don't see any supply cable going in and all I could see is the CU.
It is a Hager box, with 2 x 100A and 1 x 63A. I assume the sparky that worked on it tidied it all up and have all the tele-controlled heating related appliance on the right-hand side, dealt with by one of the 100A. Everything else that is available 24 hours are on the other 100A and 63A.
My question is, how does my set-up actually work. I know the blue cable deals with the off-peak control, but where does my supply split into 2, for the day and heat circuit? Does anyone have a wiring diagram?
Bonus question: will my set up work if I switch to a smart meter or a standard E7 meter (minus the reduced hours)
Fun fact: my current supplier (NPower) doesn't even have the meter type correctly recorded on their system...
- TL;DR
- A rare meter in London with a hidden set-up that I have ran out of clues
