Discuss How many days ? in the Business Related area at ElectriciansForums.net
Hi all,
quoting for a job of a block of 4 new build flats. 2 up 2 down with hallway/stairs/ landing in between with video door entry system to each flat . Each flat has 2 beds, lounge, kitchen, bathroom and ensuite.
looking for guidance on how many days it should take 2 sparks for 1st then 2nd fix.
thanks
Will
rough est of 1/2 hr per point first fix and 1/2 hr per point 2nd fix point should cover it. New build may let you reduce this little or add a little if a complex job.
Am thinking about this myself so would like to see comments from others as well.
Especially as all my work to date has been on existing add a plug here, change this light there, new spur from here etc so very piecemeal and a disproportionate amount of paperwork and fafing.
Reply to How many days ? in the Business Related area at ElectriciansForums.net
Hi all, I hope you could share your experience and advice regarding supply 50 flats in 5 storey block of flats. We get 3 x 430A supply. What...
I've come to a decision, I just cant do work anymore that involves mad stuff, for example today - 2 bed flat that's had fire damage, someone has...
Evening all, Currently 1st fixing new extension however the existing cooker hood duct which was on outside wall will now be part of new utility...
Hello engineers. I did EICR in two bed rented flat in a block of flats. There is old plastic fuseboard just above the entry door. There are only...
