Hi,
Just a quick question (hopefully), just put a new dishwasher in and about 15 mins into its cycle the RCD on a 16th ed. split load board covering all the sockets in the house, oven, etc. tripped, I was also running the washing machine and tumble dryer at the same time as well as other stuff that hangs off the RCD fridges, general electronics etc.
The water in the dishwasher was warm but not hot so it clearly had already started heating, so not like the heater had just clicked on and tripped it. Did a quick IR test on the dishwasher at the plug although I know thats probably not that useful as it won't cover all the components, but the reading was fine. So thought maybe its just cumulative leakage, well I checked this on the tails in the meter box, it was varying quite a bit between 15-23mA i imagine depending on cycles of appliances and stuff, but of course that's total leakage on every circuit in the house not just what's going through the rcd that tripped. So anyway I figured out this new dishwasher appears to have a consistent leakage current of around 4-5mA, just wondering really wether this is normal especially for a new dishwasher?
Seems a lot when you think the recommended limit for a 30mA RCD is just 9mA?
Cheers guys
Cheers guys
