N
nickblake
Here's one for a construction site im working on , multiple feeds to multiple flats under full renovation , i have installed a small board main switch RCD and 2 twin socket outlets for use around the site , the day i started first fix i find the supply I installed not in use and some muppet had installed sockets on the other 2 bit of 1mm 3 core flex straight off the 80 amp supply nice
and yes it was supplying the 110 volt transformer beggars belief
