Discuss How not to install a temp supply in the UK Electrical Forum area at ElectriciansForums.net
N
nickblake
Here's one for a construction site im working on , multiple feeds to multiple flats under full renovation , i have installed a small board main switch RCD and 2 twin socket outlets for use around the site , the day i started first fix i find the supply I installed not in use and some muppet had installed sockets on the other 2 bit of 1mm 3 core flex straight off the 80 amp supply nice Vira hawthorn house 003.JPGVira hawthorn house 001.JPGVira hawthorn house 004.JPG and yes it was supplying the 110 volt transformer beggars belief
builders :-(
have a look in the service fuse there is slight possibility that they busted it already and stuck a bolt in place of it.
Like the way they seem to be building a stud wall in front of it all with the stud in between the intake and isolator.
I wish I was that thick that I didn't give a ----!
Time to get the cutters out,duty of care and all that,imagine how you'd feel if someone got a belt because of that dodgy tranny.Go on you know you want to.
builders will twist wires together or use choc block if they find one in the skip then come to you asking for insulation tape.
On the second picture, how do you use the left hand side socket?!!
To to be honest, that looks better than what I have seen before lol
Reply to How not to install a temp supply in the UK Electrical Forum area at ElectriciansForums.net
So far I have never had to deal with a new supply but a possible site we are looking at will need some major changes and so I wondered if folks...
I may have posted this before but not sure if it made it in. I want to install an EV Charger in my garage. The panel is two stories up and the...
Hi all, I've just installed an APC 6KVA SRT6KRMXLI. As a computer network engineer and electrician, I was a bit baffled by the 35mm gland that...
Two related questions in 1, if anyone is up for helping! (i) When electricians install supplies, is there anything in the regs that says how many...
