Discuss How times have changed... in the UK Electrical Forum area at ElectriciansForums.net
Dustydazzler
Supporter
Back when I started out a simple board swap to a nice new plastic 16th Ed split board would set you back £400 all in including labour , maybe even a bit less.
I have just seen a quote from a well know utility provider for a consumer unit change for £1656.82
WOW
Is it just a simple board swap? Full RCBO board? SPD? AFDD? Real pita bonding run needed?
It does look really high, an I know these well known providers quite often are more expensive. Is this something you are quoting against?
bakelite is a thermosetting phenol formaldehyde resin, formed from a condensation reaction of phenol with formaldehyde. nowt to do with bakers, who make bread and cake.;););););).
I knew you would know that, having all those bread crates in the back of your van.
cheap stackable storage for materials. also qiuck to whip off if i need to put any large items in. nicked alloy wheels take up a lot of space.
Reply to How times have changed... in the UK Electrical Forum area at ElectriciansForums.net
I'm in a questions asking mood tonight. I briefely looked at a job today and I need to recommend a board change but need to justify it. Firstly...
Hi Guys I'm not a Hager user so hence the question. I've been asked to wire in lights and a fan etc for a bathroom for a mate of mine who's a...
Hi all, There's 2 single fan ovens in the house my mother recently moved into. Posh elecronic AEG units. It's been sat empty for a year, so the...
