Dustydazzler
Back when I started out a simple board swap to a nice new plastic 16th Ed split board would set you back £400 all in including labour , maybe even a bit less.
I have just seen a quote from a well know utility provider for a consumer unit change for £1656.82
WOW
Is it just a simple board swap? Full RCBO board? SPD? AFDD? Real pita bonding run needed?
It does look really high, an I know these well known providers quite often are more expensive. Is this something you are quoting against?
will the new board be gold one I wonder .any way ,I dont blame them if they get it ,when you go to bargain basement customer saying I'm not paying £400.00 quid for that cu to be changed ,can you not do any cheaper .
London board change will be £800-1000£ any less and it will likely be a cash non certified job
I accept London will always have a different price structure than rest of country. I could not comment as to whether it is a good or bad price as I don’t know the full considerations, but £800£ £1000 seems reasonable for london
It's all relative. 20 years ago a 3-bed semi in NW London suburbs was £130k. Now they're going for >£800k
is that mother's pride or hovis?
Dustydazzler,
telectrix,
