Discuss How to add a sub board when existing DB is fed by an armoured? in the UK Electrical Forum area at ElectriciansForums.net
Hi,
I have been tasked with a kitchen rewire. The current DB is fed by a 16mm armoured.
There is a split load old contactum DB which I don’t fancy buying MCBs for.
I have quoted to add a sub DB with RCBO to cover my new kitchen wiring. My question is how would you feed the new DB?
Usually I would Henley block into the tails but as it’s being fed by an armoured where do I go? I see I have three options;
Feed the sub board via a 63a MCB though this allows for no discrimination via 16mm twin and Earth.
Complete DB upgrade to allow for new circuits
Or 16mm twin and Earth into the top of the main switch.
Advice please, note getting to the main incoming supply is not an option as too far across the house!
Quote for a whole new RCBO board
If they won't have it and then I would normally 40/45amp MCB in the old board to feed my new mini sub board
I don't like the idea of coming off the top of the main switch ( yes we have all seen it done ) but it just seems a bit naff that way
I agree new CU is best or come off an MCB.
A further option if you have lots of wall is to regland the SWA into a galv box, crimp onto tails with tails gland, then Henley’s etc. this would be last choice for me, and isn’t ideal if the armour is the CPC.
I’m assuming the rewire is actually required and what is there can’t readily be adapted?
Reply to How to add a sub board when existing DB is fed by an armoured? in the UK Electrical Forum area at ElectriciansForums.net
I have been asked to provide a quote for a supply to an toilet block on a campsite. The three phase supply to the campsite is approx. 150m from...
Hi all. I have been asked to take over a job an electrician has started, and has moved abroad. The house is a big mansion, with a 3PH supply...
4K
Been asked to move, remove and add some sockets the kitchen and I’ll need to add a circuit for an electric hob. Looked at the board and it’s one...
Hi there, long time lurker, first time poster here. Straight down to it.. A friend asked me to add some sockets and additional lights to a small...
Hello all, I wonder if I can get some opinion on my deliberations on an old TPN installation with numerous 1P sub-boards wired up with 16mm T&E...
