SimpleSimon
How do people cut and strip meter tails?
I've done a connection of new tails to a CU. DNO came round to client today and said there is too much copper in exposed before they connect up. Granted I havn't finished yet and am going back next week to tidy up, but struggling to cut my meter tails neatly and enough so no copper is appearing.
Any thoughts? I was using a stanley for the sheathing but don't know what to use for the actual copper conductors.
Thanks.
use the cable shears you can buy from the wholesaler about 10 - 12 quid. secret is to form bend before you cut or you will get unequal strand lengths
i have the ck shears, do the job nicely, good tip from telectrix regarding bending the tails before cutting
I like to use a hacksaw on tails for a nice square end.
EDIT and agree totally with the pre-bend tip.
hacksaw on live tails---like it----only joking
A nice pair of shears for sure.
Same goes for SWA with regards bending before scoring the armour.
I use CK shears also. And the hint about bending then cutting is very effective.
I'd like to add onto this by suggesting that when you connect the tails into the meter, tighten the screws furthest away from the cable entry first. This will ensure a solid tight connection. This also applies to things lime Henley blocks.
Love them had mine 20 years still cut anything even use them for stripping out singles must cut about 60 at a time.
I use the shears slightly cut through the outer insulation strip off cut the inner insultaion bend to shape cut the ends square then blue and brown heat shrink over the cut outer and inner insulation makes a nice neat job
