TLC have them listed.
Plus a few extra words!!!
Things I'm referring to were a standard 35mm metal box, with a flange welded on outside, each side, about 10mm from the front, and with a 3.5mm threaded hole in the middle of the back.
You cut out a standard sized hole in the plasterboard, glued a wooden block to the inside of the opposite inside face of the wall, inserted your box, and secured it with an appropriate length of 3.5mm bolt through the hole in the back onto the wooden block.
I've never seen that, I've used the little metal wings you clip on to the outside of the box and then have to somehow hold the box in place whilst doing up the plate screws.
MK made the little metal wings to fit the back boxes.
Yes, I keep them in stock. Can be used to fit a box tight against a stud. Use a couple of wood screws to fix one end to the stud and the Mk wing on the other end.
If I know I'm going to need one the next day, I've been known to tack weld a wing in place on a box the previous evening.
